Smoke Alarm Was Sealed Off In Finished Basement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-22-2010, 10:17 AM   #1
smoke alarm was sealed off in finished basement
Hi all. I purchased a 6 year old home this past march, and lately my smoke alarms have been going off. After much troubleshooting I believe the culprit it the alarm in the basement, problem is that whoever finished the basement has sealed off the alarm . Basement has 3 rooms and I have narrowed down the room I believe it is in, but after cutting one hole already and not finding it I am hesitant to cut more.
Does anyone have any tips of advice on how I can find this little bugger?? Much thanks!
Stl_home is offline   Reply With Quote
Old 06-22-2010, 10:22 AM   #2
Are they all hard wired together ?
If so set them off & use a cup against the basement ceiling to find it
Old 06-22-2010, 10:29 AM   #3
They are hardwired, and I tried using a cup but couldnt really pinpoint. Think I may try a Mechanic's Stethoscope and see if that might help.
Old 06-22-2010, 05:52 PM   #4
Rewards Points: 5,336
Disconnect all but the unit furthist away. Set off this unit while someone is in the basement. You should be able to narrow down the location by the sound.
Ron
Old 06-22-2010, 07:47 PM   #5
If you know a telephone repair man, borrow his tone generator and probe.
Shut off the breaker and hook the generator between ground and the detector feed wire.
Follow the signal with the probe.
Phone guys do this all the time.
Alarm for basement flooding? mikehende Plumbing 9 08-16-2013 02:32 PM
Cold Room in Finished Basement Creekbender Building & Construction 4 01-31-2010 08:54 AM
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 08:09 AM
Finished Basement Remodel Questions bioguy Remodeling 6 11-15-2007 09:56 PM
Installing Registers in finished basement boinger HVAC 2 02-07-2007 03:44 PM
