Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-25-2008, 04:50 PM   #1
small holes in drywall mud
We are wiping down the drywall to prepare it for the primer. We noticed as we were wiping down the mudded area tiny holes have appeared. Is this normal? Any suggestions as to why this is happening and what is the easiest way to fix them?
Thanks,
kimmyb is offline   Reply With Quote
Old 01-25-2008, 06:58 PM   #2
Sand lightly and re-skim. These are air bubbles that you are removing the tops of.
kgphoto is offline   Reply With Quote
Old 01-25-2008, 09:18 PM   #3
Remodeler
MinConst's Avatar
Mixing the mud first help resolve this also. It makes it nice and creamy with less air pockets.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 01-26-2008, 09:25 AM   #4
Thanks sooo much! Both suggestions have been very helpful!
Old 01-26-2008, 09:35 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You will need a couple of coats to properly fill-in the air holes.
The reason why they didn't show up before is because they were filled with the drywall dust. When you wiped the walls down, the dust came out.
not a big issue - very common.
Good Luck...
- Build Well -
Old 01-26-2008, 10:21 AM   #6
Thanks very much! Every bit of info helps!
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
