-   -   small holes in drywall mud (http://www.diychatroom.com/f2/small-holes-drywall-mud-16145/)
kimmyb 01-25-2008 03:50 PM
We are wiping down the drywall to prepare it for the primer. We noticed as we were wiping down the mudded area tiny holes have appeared. Is this normal? Any suggestions as to why this is happening and what is the easiest way to fix them?
Thanks,:(
kgphoto 01-25-2008 05:58 PM
Sand lightly and re-skim. These are air bubbles that you are removing the tops of.
MinConst 01-25-2008 08:18 PM
Mixing the mud first help resolve this also. It makes it nice and creamy with less air pockets.
kimmyb 01-26-2008 08:25 AM
Thanks sooo much! Both suggestions have been very helpful!
AtlanticWBConst. 01-26-2008 08:35 AM
You will need a couple of coats to properly fill-in the air holes.
The reason why they didn't show up before is because they were filled with the drywall dust. When you wiped the walls down, the dust came out.
not a big issue - very common.
Good Luck...
kimmyb 01-26-2008 09:21 AM
Thanks very much! Every bit of info helps!
