Small Holes In Drywall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-25-2013, 10:57 AM   #1
Small holes in drywall
I've been in my current house for about 2 years and have notice these small, maybe 1/8", holes that were drilled into the drywal just above the baseboards. I didn't think much of it and figured they switched the baseboard out at some point and these were just nail holes left from the old moulding. Well I just realized that the holes are only drilled in the exterior walls and they are even present above the hot water heat baseboards. I even see the same holes drilled into some wood paneling about 12" up from the floor (to hide them in a seam). They also seem to be spaced out to be in each bay of the wall.
Has anyone ever heard of a reason for drilling these small holes into the bays of the exterior walls? My only thought was maybe it was for an exterminator to shoot some pesticide spray in.
Anyone seen this before???
NHtransplant is offline   Reply With Quote
Old 02-25-2013, 11:01 AM   #2
Rewards Points: 13,300
Could be though I've never seen it done that way. More likly a DIY did it.
Old 02-25-2013, 02:34 PM   #3
MarginallyQualified
Rewards Points: 2,464
I've seen that sort of thing done on OLD houses in order to find the studs...
Old 02-25-2013, 03:45 PM   #4
The house was built in '68 and a large addition was put on in about '80. The holes are there on the old and new part of the house. Holes are only on the first floor.
Old 02-25-2013, 08:46 PM   #5
firehawkmph's Avatar
Rewards Points: 1,826
I'm going with what Tarheel said. Redneck studfinder. Can you see any evidence of the baseboards being nailed right under those drilled holes? Stick a small nail in the hole. It should only go in a little deeper than the drywall and stop. If that's all they are is studfinders, go ahead and spackle or patch them and touch up with paint.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-26-2013, 08:15 AM   #6
r0ckstarr's Avatar
Rewards Points: 1,998
Wouldn't the exterminator drill at the tops of the walls to get more coverage inside the wall?
r0ckstarr is online now   Reply With Quote
Old 02-26-2013, 08:39 AM   #7
That's a good point rockstarr.
The holes are definitely in the bays not at the studs. I stuck a stick in a bunch of them and didn't hit studs.
I'm not worried about what the holes are, I'm just curious what the point was. I thought maybe someone would have seen it before but it may be just some DIY think that the PO did for some reason.
Old 02-26-2013, 05:39 PM   #8
Rewards Points: 18
Hi.
Long time lurker who just signed up.
My neighbor had Orkin over due to carpenter ants, and they drilled holes just as you described. Sprayed some type of powdered insecticide into each hole.
Jeff
Jtom is offline   Reply With Quote
Old 02-26-2013, 09:16 PM   #9
That's helpful Jeff. Thanks. I'll bet that's it. The house was empty for a while and I know the PO had an exterminator here before we looked at the place because there were bait stations and mouse traps in the basement. The good news is that I've had a friend over from Terminex before and he looked the place over and everything looks good now.
How to drill small holes in tile Robert95z Flooring 7 12-25-2012 07:51 AM
How to patch up these small drywall holes in the ceiling? htabbas Drywall & Plaster 7 12-23-2011 11:57 PM
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 11:35 PM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Repairing a small hole in drywall jweiner Drywall & Plaster 9 01-28-2009 09:53 PM
