Small Engine Tachometer - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-01-2011, 10:41 PM   #1
I have been working on a lot of single and twin cylinder engines lately. Several times I have needed a tachometer to set max rpm.
Any suggestions as what to get?
Giles is offline   Reply With Quote
Old 01-01-2011, 10:59 PM   #2
Experienced
Jackofall1's Avatar
A strobe light would work the best.
Old 01-01-2011, 11:32 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,650
Ayuh,.... Tiny Tach,...
Bondo is online now   Reply With Quote
Old 01-02-2011, 08:30 AM   #4
Household Handyman
Rewards Points: 1,408
You state you are "working on a lot of" small engines lately. You may want to look into the hand-held optical or laser tachs which do not have to be attached to the engine. Just point at a revolving part. These are a bit pricey, in the $150 range, but are very accurate, hand held, and stay with you. I own one and used it in industrial applications. Worth it's weight on gold when needed.
Old 01-03-2011, 01:18 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
You could try this.
http://cgi.ebay.com/ebaymotors/Hour-...item27b4a8536f
Old 05-06-2011, 06:50 AM   #6
Try this small engine tachometer . Looks pretty similar to the Tiny Tach brand. Good luck.
jimmy2001 is offline   Reply With Quote
12"x12" Tile Layout on SMALL (15"x24") Countertop? mirzai_m Kitchen & Bath Remodeling 6 01-11-2010 12:28 PM
Fixing small area of tiles on the wall Curious123 General DIY Discussions 3 09-09-2009 07:41 PM
Small engine troubleshooting no mechanic Tools 2 09-21-2008 09:56 PM
Big HVAC Guy vs Small HVAC Guy flysndoc HVAC 4 09-20-2008 11:06 AM
Curved Small Stage jalaux Carpentry 1 07-09-2006 09:57 PM
