-   -   Small Engine Tachometer (http://www.diychatroom.com/f2/small-engine-tachometer-91009/)
Giles 01-01-2011 11:41 PM
I have been working on a lot of single and twin cylinder engines lately. Several times I have needed a tachometer to set max rpm.
Any suggestions as what to get?
Jackofall1 01-01-2011 11:59 PM
A strobe light would work the best.
Bondo 01-02-2011 12:32 AM
Ayuh,.... Tiny Tach,...
Thurman 01-02-2011 09:30 AM
You state you are "working on a lot of" small engines lately. You may want to look into the hand-held optical or laser tachs which do not have to be attached to the engine. Just point at a revolving part. These are a bit pricey, in the $150 range, but are very accurate, hand held, and stay with you. I own one and used it in industrial applications. Worth it's weight on gold when needed.
Maintenance 6 01-03-2011 02:18 PM
You could try this.
http://cgi.ebay.com/ebaymotors/Hour-...item27b4a8536f
jimmy2001 05-06-2011 07:50 AM
Try this small engine tachometer . Looks pretty similar to the Tiny Tach brand. Good luck.
