Small Engine Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-09-2006, 05:48 PM   #1
Rewards Points: 16
Small engine problem
I'm trying to replace the engine on my log splitter. The original engine was an 8HP Tecumseh snowblower engine that has seen better days. I found a replacement today: 8HP Tecumseh snowblower engine, same mounting, same shaft location, same RPM. Only problem is the old one had a 1 inch dia shaft and the new has a 3/4 inch diameter shaft. Any ideas on how best to match up the new engine to the existing coupling?
I understand that they make keyed bushings that increase the diameter, but I haven't been able to locate any such thing. Thanks for your help.
rkhpapa is offline   Reply With Quote
Old 12-09-2006, 09:00 PM   #2
SnoBird
Replacement Engine
Some brands of couplings are available with different size bore on either (each) end. Maybe you could be lucky and find the one you need. Would beat a bushing!
SnoBird
SnoBird is offline   Reply With Quote
Can a DIY build a small in-ground swimming pool? zel General DIY Discussions 14 06-15-2013 10:42 AM
Small engine repair tripower Tools 2 07-09-2009 04:28 AM
Number of circuits needed for a small kitchen? All responses welcome! alexz Electrical 5 04-07-2007 11:38 AM
Engine Slowly Loses Power and Dies While Driving slickshift Automotive Repairs 16 01-15-2007 12:34 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
