Small Engine Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-08-2008, 04:13 PM   #1
Exclamation
small engine problem
tecumsuh 8hp snowblower,it has been sitting for 2 years according to last owner, it will start but during this time engine is running, oil coming out of valve cover hose, shut it down once i noticed this ,it will only run for a short time with a lot of backfiring , tried to adjust carb , no effect , please advise.
michael4 is offline   Reply With Quote
Old 11-09-2008, 10:46 AM   #2
check the oil before starting. when it is fully settled in the crank. then run it until you see the oil come out the valve cover hose. then shut it off and quickly check the oil. If it is low it may be that an oil return hole is clogged. I a just guessing, it happened on one of my cars.
after sitting two years it might be time for a tune up. Some new gaskets, filters, plug. and carb cleaning. Or you could just change start with a new plug, filters and such, spray carb cleaner while running before changing all that stuff.
Mikeeee
pmracing is offline   Reply With Quote
Old 11-09-2008, 10:51 AM   #3
High pressure in the crankcase, some relief port is blocked.
Small gas engine problem Studiohio General DIY Discussions 2 03-08-2008 09:03 PM
Basement remodel, I need help figuring out moisture problem hampton72 Remodeling 1 03-07-2008 10:30 AM
small electric heater recommendation bdog1234 Electrical 9 02-24-2008 02:12 PM
furnace problem captjack HVAC 8 11-23-2007 11:15 AM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 07:24 AM
