Slump Block Insulation? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-27-2008, 08:44 PM   #1
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Slump block insulation?
I have a couple of bedrooms with slump block walls that get really cold. I was thinking of firring out the walls and maybe putting in some thin insulation, but I don't want to lose too much space in these little rooms. Maybe just fir out 1" or so? Will this work? Should I just build closed-back shelves and be done with it?
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 12-27-2008, 09:49 PM   #2
Hi everyone, sorry i don't know. what is a slump block foundation?
Frederick j Ward is offline   Reply With Quote
Old 12-29-2008, 01:31 AM   #3
Fixer-'til-broker
Rewards Points: 262
Slump block is a type of large brick used to build walls, commonly in arid climates. The foundation is a slab of concrete. The house was built in the 1970's, so they didn't have the technology to insulate the slump block internally yet.
Old 12-29-2008, 06:21 AM   #4
I would think cool walls would be welcome in AZ. But there is an EPS(expanded poly styrene) foam product at big box stores, 2'x8', 2" thick, with slots for furring strips. It goes directly on the wall, secure with tapcon screws thru furring strips into foundation. About R10, if I remember right.
Old 01-02-2009, 10:14 PM   #5
Fixer-'til-broker
Rewards Points: 262
Thanks, Bill. Yes - cool walls are welcome in the summer and about 70% of the year, but not in the coldest part of the year. The insulation would help with the heat on these very same walls. The coldest rooms are also the hottest...if that makes any sense...
Old 01-04-2009, 12:42 PM   #6
Here in Canada, we used to use 1" foam insulation (R5) but now we use a minimum of 3 1/2" (R12). The beauty of insulation is that it keeps the heat in, in the winter and the heat out in the summer! Saves A/C costs!
In your case, I would suggest that you would use 2" of foam (R10) as the space taken up, in the room, is negligible!
One thing that I have noticed as a Snowbird is that if it gets really cold in your area, generally speaking, the buildings are not prepared for this! So it gets really uncomfortable. Whereas, we have our homes prepared for the cold and usually are quite comfortable!
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
84' Slump block wall $10,000??? dbsanders General DIY Discussions 2 07-09-2008 08:13 AM
Can foam sealer be used to seal the spaces in concrete block? marksto Building & Construction 6 04-21-2008 07:48 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
