Sloping Floors - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-12-2013, 01:51 PM   #1
sloping floors
Hi I'm looking for some advice on sloping floors. I've recently moved into a new house and noticed significant floor sloping. In some cases approximately 1" over a length of 12'. What's particularly interesting is I will also see a 1/4 deviation over 3'. Someone looked at the foundation and said it's perfectly level. The problem seems to be mainly sloping in the inside of the house. One thought is I have heavy hardwood floors that may be pulling down the center of the house. This is pretty scary. Any advice or thoughts on how to fix this would be great. Thanks
achillez is offline   Reply With Quote
Old 11-12-2013, 02:17 PM   #2
Rewards Points: 13,722
How old is this house?
What's the spacing, width and free spans of the floor joist?
Got any picture from under the floors?
How did they check the foundation, you can not just look at it, lot more to it then that.
Hardwood floors have nothing to do with "pulling down" a floor.
More likely undersized, over spanned joist.
Gymschu (11-12-2013)
Old 11-12-2013, 03:54 PM   #3
DIY staff
Rewards Points: 7,174
We need pictures or more info---is this the first floor or a second floor?
Is there a center beam in the basement? Is it possible a bearing wall has been removed improperly?
Termite damage? A plumber with a Sawsall clipped the bottom of a few floor joists?
Who looked and checked the foundation?
Old 11-12-2013, 04:21 PM   #4
Rewards Points: 5,974
Maybe just floor joists sagging from age. Do they slope toward the middle of the house or toward one certain wall or area?
Old 11-12-2013, 04:58 PM   #5
Gymschu's Avatar
Rewards Points: 838
Could be lots of things……..undersized or sagging joists that has been mentioned. Is there a chimney in the center of the house? I've seen homes sag from an improperly installed chimney that settled & pulled down on the framing of the house. I've seen homes that had either poorly installed footers or no footers at all and this cause all sorts of problems. You really need to do some serious investigation. Hopefully, you have a friend that is a structural engineer that could take a look.
Old 11-13-2013, 11:35 AM   #6
more info
thanks for the comments. Here's some more detail:
The house was a remodel done ~8 years ago. Square footage was doubled. It's unclear exactly what was done but it appears a new foundation was created next to the original house.
The sloped floors occurs on the 1st floor most prominently, but also observed on the 2nd floor. Oddly the 1st floor (which is hardwood) has all the squeaks. Upstairs has some areas with steeper slopes, but they are less erratic. E.g., one area slopes cleanly for across a 10x10' area then levels off.
We had a foundation expert come. They spent a couple hours checking out the floors, measuring height differences from one end to the next, examining joists and beams.
Conclusion was that the foundation was perfectly fine and level. The hardwood floor is too heavy for the 1st floor. The crawl space could add 1 or 2 more beams to help level the kitchen. I'm now wondering who else I should bring in to do a professional job on this. I don't want to "hack it" with a couple beams and hope the problem goes away.
Old 11-13-2013, 12:14 PM   #7
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,166
Originally Posted by achillez View Post
Conclusion was that the foundation was perfectly fine and level. The hardwood floor is too heavy for the 1st floor. .
Say what?
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
Old 11-13-2013, 12:24 PM   #8
Originally Posted by 123pugsy View Post
Say what?
The foundation (cement around the outside) is level. From corner to corner, and end to end the floor has not shifted and is the same height. The slope (or sag) is happening in the middle of the floor due to "perhaps" not enough beams/joists.
Old 11-13-2013, 01:26 PM   #9
123pugsy's Avatar
OK. so the hardwood flooring is not too heavy.
The joists are inadequate.
Are they exposed below?
Can you get pics as asked for previously?
Old 11-13-2013, 03:09 PM   #10
It was not what they said, it was how they said it that was funny.
Hardwood is to heavy? Undersized, over spanned joist may have been a better way to word the real problem.
Very common problem with older or cheaply built homes.
I see 2 X 8 joist and 1/2 subflooring all the time. Both will always cause issues.
A row of properly sized footings and a doubled up beam run down the middle of the span in most cases will take care of the sag and the bounce in the floors.
How to Recoat (Sandless Refinish) Hardwood Floors RhodesHardwood How To Guides 11 03-12-2014 11:42 PM
Refinishing of oak floors gone bad voodoochile Flooring 10 06-21-2012 01:15 PM
i have a row home with sloping floors.... edwin1985 Building & Construction 10 12-05-2010 11:42 AM
Sloping floors KDH Flooring 1 03-15-2010 01:25 PM
Sloping Engineered floors to level with next room jholschuh Flooring 2 09-07-2009 10:28 PM
