Slight Slope To Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-09-2007, 09:02 AM   #1
Slight slope to floor
My husband and I have found a house we want to buy, but there's one issue that concerns me.
The house is on a crawlspace foundation. It was built in the early 60's. As I walked through the house all the floors seems stable and not very creeky with the exception of the kitchen. Maybe it was more obvious since that room was linoleum and the rest is carpeting. The floor had a slight slope to it, sloping toward the outside of the house. It was also a little squeaky sounding.
Is this something to be worried about?
The home inspector is coming next week to take a look at everything, that I thought you guys might offer some advice about, or at least suggestions of intelligent questions I can ask the home inspector.
sweetsue777 is offline   Reply With Quote
Old 01-09-2007, 11:31 AM   #2
Rewards Points: 528
I would walk away from it. It could be a major repair or worse. I had a nephew that bought a row home and his and the neighbors houses were all noticeably leaning to the rear which was detectable as soon as one entered. When a building inspector inspected them, he ordered everyone out of their homes and condemned them. There was a big stink over this and the city decided to satisfy all affected by finding other homes for them at little or no cost. The houses in question were built over a creek and in time, the water undercut the soil weaking the foundations in the rear of the houses.
If you decide to bid on this house, make sure to check out the home inspectors credantials and ask to have a copy of his liability insurance.
Because if he is wrong in his assessment of the property, you can sue for damages. Call a General contractor and ask if the slant can be permenantly corrected using approved methods to meet code.
rjordan392 is offline   Reply With Quote
Old 01-09-2007, 12:32 PM   #3
Rewards Points: 150
My house is the same construction built in 1952. The subfloor is supported by wood posts set on top of concrete pier blocks with beams running between the posts. 54 years and one major earthquake later our kitchen floor slopes a little also, but not so that it's really noticeable and we had the foundation inspected and certified by an engineer before buying it. If you're concerned, get an engineer to inspect it after the regular inspection is done. It should only be $250 or $300 and you can keep the inspection report (provided it passes) with your other home documentation to show buyers if you ever want to sell the house.
billinak is offline   Reply With Quote
Old 01-10-2007, 01:58 PM   #4
I would find out the cause before making any rash decisions. It might be anything from needing to jack up and/or replace a beam to misplaced weight somewhere - in our case, we found that the reason for upstairs floor sagging between beems was because the people that built the place put in two brick chimneys, not supported (they dont go all the way to the ground).
ShariLynn is offline   Reply With Quote
Shower floor slope Not Sure Building & Construction 11 06-10-2008 12:12 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
Noticeable slope on main floor... andersp Building & Construction 13 01-17-2007 08:59 AM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Floor joist lower than others drhowarddrfine Flooring 2 04-26-2006 04:25 PM
