Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-21-2008, 07:25 PM   #1
sliding screen double patio doors
I can't get my sliding screen door off to replace the screen. It has a lip on the top and bottom that even with the loosen screws wont clear without bending the frame or breaking the front of the lip.
They are lightweight metal doors. I've changed other screen sliders so I know about the wheels but I've never seen doors that don't seem to have a way to take them off? the frame doesn't have screws to take off so I'm really confused,
bcrest is offline   Reply With Quote
Old 10-22-2008, 08:04 AM   #2
Derpending on design, you may need to either remove the screws or run them all the way in. This will either raise or lower the door with sufficient clearance to pull the door away from the top or bottom. You may also need to raise the door by hand to get clearance at the bottom.
See if this works for you.
rjordan392 is offline   Reply With Quote
Replacing a HUGE sliding glass door w/ a hinged patio door. ZeroTX General Discussion 12 05-02-2013 11:39 AM
8' Glass Sliding Doors dankreboot General Discussion 6 07-10-2008 09:11 AM
outswing patio doors philS Building & Construction 2 07-11-2007 02:39 AM
Sliding Patio Door Installation flyultralite Building & Construction 11 05-04-2007 12:06 PM
Crestline Patio Doors tom_patriot Building & Construction 2 11-24-2006 11:51 PM
