Sliding Door Systems By Andersen - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-01-2011, 01:19 PM   #1
Sliding door systems by Andersen
I recently ordered (from my new home builder), what I thought was a 9' sliding door system by Andersen. I looked at Andersen's website but could not draw a final conclusion to this question: Would a 9' slider be two systems e.g., a standard 6' slider with a separate 3' panel, or would it be a single 9' slider system?
Dave Drab is offline   Reply With Quote
Old 01-01-2011, 04:04 PM   #2
firehawkmph's Avatar
Rewards Points: 1,884
Dave,
I would suggest you check back with your builder and see exactly what he ordered. I looked at Andersen's site and if you are looking at the 400 series frenchwood gliders, it looks like you would have to pair up a 6 footer with a 3' stationary panel. The custom size page is a little vague.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-01-2011, 04:42 PM   #3
Mike,
I will do that. I saw what appeared to be a single unit in a model. I ordered the same, but two separate units were actually delivered. I'm afraid the stud between the 6' door and panel will not look like right as the model.
Thanks again,
Dave
Old 01-01-2011, 09:04 PM   #4
Dave,
check on that stud being there. Your rough opening should be for the whole 9'. Andersen usually has their products set up to mull together to look like one unit when done.
Mike Hawkins
Old 01-01-2011, 09:25 PM   #5
Stud
Mike,
Thanks. I'll check into that. Sounds like my concern will be satisfied with correct installation.
Dave
Old 01-02-2011, 06:55 AM   #6
It probably is designed to be an on site mull. Handling a 9' door is hard, even for a crew of guys.
The Following User Says Thank You to Just Bill For This Useful Post:
Dave Drab (01-02-2011)
Andersen door will not stay open Judy Nichols Building & Construction 5 09-30-2010 11:23 AM
Condensation on baseboard by sliding doors... Donmills Flooring 0 06-28-2010 08:35 PM
Andersen Sliding doors squeek constantly JackVa1 Remodeling 4 08-28-2009 08:52 PM
Outswing french doors Pooch40 Remodeling 8 05-30-2009 03:47 PM
Andersen Sliding Door jphelps Carpentry 3 01-26-2009 07:20 PM
