Sleeving Pipe Through Basement Wall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-23-2008, 12:57 AM   #1
sleeving pipe through basement wall
Hello,
I would like to sleeve 3" diameter pvc pipe through my basement wall approximately 2' below outside grade. I plan on running polyethylene pipe from an outdoor wood boiler to inside of the basement then to my furnace. I am not sure how or what to use to seal the 3" pvc pipe penetrating through the cinder block wall. I don't want any water leaking into the basement. Is there a certain concrete mortar mix the I can seal the pipe penetrating the wall? In addition to that, I am not sure about how to seal the inside of the 3" diameter pvc pipe where the PEX runs through. Any ideas on that? Thanks for your time reading this post and replies.
KPH120 is offline   Reply With Quote
Old 01-23-2008, 06:08 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,.....
I'd seal the 3" conduit with Hyd. Grout,.....
And,....
I'd seal the Pex tubing inside it with Spray Foam......
Bondo is online now   Reply With Quote
Old 01-23-2008, 08:19 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Touched on already. Key material is going to be hydraulic cement on both sides. Any kind of caulking or sealant will not be strong enough to hold against hydrostatic pressure.
http://www.askthebuilder.com/B119_Hy...c_Cement.shtml
The Big Home Improvement stores carry this: http://www.doityourself.com/invt/u648693
- Build Well -
Basement knee wall question vugger Building & Construction 2 01-05-2008 10:02 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 10:16 AM
