Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-18-2011, 05:26 PM   #1
Slant in Stairs
The last 6 steps or so on my staircase slant to the right about .4 inches to .75 inches at its worst. The slant goes towards the wall as seen in the pictures. What could have caused this and is this something to fix or just live with. The house is about 20 years old.
Gerard
Slant in Stairs-image-1938208337.jpg   Slant in Stairs-image-2279921756.jpg   Slant in Stairs-image-1738195542.jpg
gerardswork is offline   Reply With Quote
Old 12-18-2011, 06:07 PM   #2
Slant in Stairs
Could be lots of things. Could have been that way when it was built, center of the bulding is sagging, ect.
Old 12-18-2011, 06:18 PM   #3
Slant in Stairs
Thanks for the reply...off the stairs nothing else is sagging...there aren't any slants related to this one....
What should I do to eliminate the reasonings? Is this something that can just happen?
Old 12-18-2011, 06:26 PM   #4
joed's Avatar
Slant in Stairs
Are you sure the stairs are sagging or is the carpet worn?
It was either build wrong, something sank or least likely something rose.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-18-2011, 07:36 PM   #5
Disabled wood vet
titanoman's Avatar
Slant in Stairs
Its slightly possible you could have a cracked stringer, which would require major remodeling.
Is there a room you can get to under the stairs?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
Willie T (12-20-2011)
Old 12-19-2011, 11:40 PM   #6
Slant in Stairs
Can't easily access stairs...it doesn't bother me enough to go to town on it...just curious as to why...I'm guessing cheaply built with a little settlement.
Old 12-20-2011, 12:58 AM   #7
STAFF
BigJim's Avatar
Slant in Stairs
If it has just sagged in the recent past I would be concerned, something isn't right and I would be concerned enough to find out why.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
Old 12-20-2011, 09:38 AM   #8
Slant in Stairs
Can you access the bottom of the stairs? What does the stringer sit on at the first step? Does the floor, at the bottom of the stairs, feel bouncy or sagging?
packer_rich is offline   Reply With Quote
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
Outdoor stairs need to be fixed... 2031pratt Carpentry 4 12-01-2011 06:55 PM
Building Code Requirements: Basement Stairs (Quantity) dutchswan0311 Building & Construction 27 09-19-2011 07:13 PM
Help with staining my stairs kimber Flooring 2 12-04-2009 08:45 PM
Strengthening stairs with less support HitLines Remodeling 1 10-30-2009 12:45 AM
