Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-18-2010, 04:54 PM   #1
Slab on grade garage?
It appears that the last owner of my house took a paved parking stall and build a garage on it. I get some slight leakage under the walls, but everything is pressure treated so its not THAT bad..
What can I do to help keep the water out?? Also this is fully sided and the siding goes all the way down to the dirt, is there a way to prefect the siding with it being so low?
cbzdel is offline   Reply With Quote
Old 06-18-2010, 07:42 PM   #2
Civil Engineer
Post some pictures. Tell us what the foundation is for the garage. What is the siding made of. I assume prefect is a typo, what did you mean? Why is the water coming in, does the grade slope towards your garage? Do you have gutters?
Old 06-18-2010, 09:03 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
So, they basically took a Carport & enclosed it, you are saying.
Old 06-19-2010, 06:23 AM   #4
Moderator
Most garages are built with footings and stub walls or thickened slabs of concrete. Building codes require this to protect the siding and framing materials from rot and water damage. Anything less is structurally unsafe and prone to rot. Pictures would be helpful.
Be safe, Gary
Clothes taking longer to dry?
engineer wood floor @ uneven Slab on grade gtimk4 Flooring 0 03-21-2010 07:29 PM
Garage siding too low (at grade), plus drainage problem pfisch Building & Construction 14 03-10-2010 11:41 PM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 07:13 AM
Sink hole under garage slab. diggitydog Building & Construction 3 08-31-2006 01:49 PM
Garage Concrete Slab...HELP? Aqua-Man Building & Construction 2 06-17-2005 02:11 PM
