Skylite Dripping - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 12:48 PM   #1
Skylite dripping
My skylight in the bathroom will drip at the lower corners in the winter. I went on the roof and noticed there was a small amount of water in the lower sill area below the window. Is there suppose to be a drain hole to the roof that may be blocked?
dtl2761 is offline   Reply With Quote
Old 01-11-2010, 12:59 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
no drain hole from the inside if the glass to the outside i believe,that would cause even more condensation,but there could be internal frame drains
usually on the lower part of the unit there is a condensation gutter where any water that collects will eventually evaporate,cold temps outside and very high humidity inside can overwhelm this
Tom Struble is offline   Reply With Quote
Old 01-11-2010, 01:01 PM   #3
There could be a couple of factors. is there a shower in that bathroom it could be condensation making it drip or the window is contracting from the cold temperatures breaking a seal some where letting water in. You'll have to get up in the sky light and do some further investagating
altima is offline   Reply With Quote
Old 01-11-2010, 01:09 PM   #4
So the condensation gutter will not drain to the outside? It is supposed to evaporate only? I have the same skylight in the hall that never has water in the condensation gutter. So it must just be the bathroom location and use of the shower. I just thought there should be someway this water can be drained out.
Old 01-11-2010, 03:44 PM   #5
Rewards Points: 5,336
If you have a good vent fan and leave it on a decent amount of time, the issue should disappear.
I have a 30"x 48" skylight in my bath(5'x7') and haven't had any issue using a Fantech vent with a 6" exhaust.
Ron
What is this contraption in front of my house? Why is it dripping? fritzycat1 Plumbing 15 08-06-2009 04:23 PM
Broken handle and dripping sound Sliding Man Plumbing 3 04-16-2009 02:03 AM
Bathroom Fan Dripping mntnbkr General DIY Discussions 12 12-06-2008 12:08 PM
Shower Dripping Hot Water, Should I Shut Off Emergency Oil Burner Switch? bman46 HVAC 1 10-02-2007 02:04 PM
