Skylight Flashing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-16-2009, 09:50 AM   #1
PCL
skylight flashing
Hello,
We are attempting to get old skylights replaced and have a quandry: if the current skylights are not leaking, do we need to replace the flashing? Apparently this is a big job and will cost an additional $1,150.
PCL is offline   Reply With Quote
Old 07-16-2009, 09:57 AM   #2
Skylight flashing is comprised of multiple pieces
Much of the flashing can be re-used depending upon how it was installed & nailed
But - you can't simply leave the flashing in place & re-roof
It needs to be removed & re-installed - more labor
My head flashing & sill flashing are easily removed & then re-installed
The step shingle flashing can be a little harder to remove
I think replacement pieces are ~ $1 each
New flashing for a skylight is anywhere from $45-70 from what I have bought myself
This all depends upon your brand of skylight - Mfg
Old 07-18-2009, 08:05 AM   #3
Roofing Contractor
Leftyho's Avatar
Hi,
Your post is unclear.
Why are you replacing the skylights? You said they did not leak?
How would you replace skylights without flashing?
Not enough information.
SunTunnel Skylights
Leftyho is offline   Reply With Quote
Tubular Skylight - Flashing Issues lrsuffi@yahoo.c Remodeling 2 06-30-2009 05:07 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
Flashing skylight curbs with architectual shingles PerpetuallyRepairing Roofing/Siding 3 05-30-2009 06:01 AM
when to replace a skylight & flashing question CindiChm Roofing/Siding 3 10-08-2007 09:18 AM
