-   -   skylight flashing (http://www.diychatroom.com/f2/skylight-flashing-48972/)
PCL 07-16-2009 09:50 AM
skylight flashing
Hello,
We are attempting to get old skylights replaced and have a quandry: if the current skylights are not leaking, do we need to replace the flashing? Apparently this is a big job and will cost an additional $1,150.
Scuba_Dave 07-16-2009 09:57 AM
Skylight flashing is comprised of multiple pieces
Much of the flashing can be re-used depending upon how it was installed & nailed
But - you can't simply leave the flashing in place & re-roof
It needs to be removed & re-installed - more labor
My head flashing & sill flashing are easily removed & then re-installed
The step shingle flashing can be a little harder to remove
I think replacement pieces are ~ $1 each
New flashing for a skylight is anywhere from $45-70 from what I have bought myself
This all depends upon your brand of skylight - Mfg
http://nrha.web-pros.com/How-To/door...ights/9083.jpg
Leftyho 07-18-2009 08:05 AM
Hi,
Your post is unclear.
Why are you replacing the skylights? You said they did not leak?
How would you replace skylights without flashing?
Not enough information.
SunTunnel Skylights
