Sky Light Replacement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-08-2010, 04:43 PM   #1
Post
Sky light replacement
I am trying to assess whether I should take on a skylight replacement job on screened-in porch roof which has a slight pitch. As I understand all I have to do is remove the shingles around the existing skylight, pry or unscrew the fasteners, remove any caulk or tar that seals out water, and then pull out the sky light.
I would then reverse the process by making sure the sealant is continous and full while I fasten the new skylight, then re-shingle so that water rolls off like it does on a ducks tail.
Can it be any more complicated than that?
I appreciate your feedback, Myco
Myco is offline   Reply With Quote
Old 05-08-2010, 05:40 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
What type s/l exists and what do you intend to replace it with?
The "trouble bubble" type units rely on some type of sealant to keep them from leaking. A true curbed s/l (Velux FS, for instance) will typically have a flashing kit available with good instructions attached. Finding a replacement unit to fit the existing hole is sometimes a challenge.
seeyou is offline   Reply With Quote
Tags
home builders , roofing contractors
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 11:58 AM
