#1 |
Simplified/Summary CA Building Code?
I have tried to read the building code in its entirety, but it is way too long and gruesome to read it all. Even skimming it is too difficult, seems like the most important info are hidden. Most of it seems to be things that don't apply to single family residential homes. Definitely not DIYer friendly.
Is there anywhere I can find building codes simplified for residential use only? For example, list of requirements for most common rooms of a home, kitchen, bedroom, bathroom, living/dining room, garage. Last edited by acerunner; 03-17-2010 at 05:52 AM. |
#2 |
In the olden days codes went something like this: " install per manufacturers recommendations and good practice of the trade."
![]() As it was discovered by some that some quality could be removed from products and short cuts in labor were promoted to increase profitability: the code books got thicker and thicker...and they are still growing.
#3 |
Moderator
Code Check booklets are found at H.D. Like this: http://www.codecheck.com/cc/images/CC5thEdSample.pdf
They have specific ones for: Building; Electrical; Plumbing; HVAC; West States; and Code check- a guide for building (which has an assortment taken from all the books). Be safe, Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| The Following User Says Thank You to Gary in WA For This Useful Post: | acerunner (03-17-2010) |
#4 | |
Simplified/Summary CA Building Code?Quote:
#5 |
I am in CA and have found my local building department folks to be very helpful. From planning and permitting, and then into the job. I have requested pre-start onsite consultations which have been very productive. And then with each inspection I review next steps with the inspector and what is needed, common mistakes he finds and how to avoid, etc.
The code check books already noted are very useful as well. |
#6 |
Moderator
The Code Check books would be my first suggestion. However, they only scratch the surface of what you need to know in order to do work to code. They aren't all-encompassing and a solid knowledge of wiring methods, for instance, is still required in order to do it right. They're good for referencing basic dimensional requirements, receptacle placement, drain size, etc.
| Display Modes | |
| Building a temporary workshop inside of large pole building | HandyDave | Building & Construction | 0 | 02-17-2010 09:39 PM |
| Finding a copy of the 2006 International Building Code | WFO | Electrical | 2 | 07-11-2009 08:21 PM |
| Handrail building code questions - Canada | Peterpantz | Carpentry | 7 | 10-26-2008 01:24 PM |
| Buidling code for deck and nailing schedule | Jozee | Building & Construction | 7 | 10-01-2008 01:46 PM |
| Another Bryant 383KVA with code 31 problems | rpgIVguru | HVAC | 1 | 02-05-2007 02:47 PM |
