Simple Pool Solar Heater - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-18-2013, 04:31 PM   #16
DIY staff
Rewards Points: 7,174
You are doing it! Bravo!
Jim and Creeper--I left the original piping and added two Ts to feed the hoses--one for 'in' one for 'out'--each one had a shut off so the heater could be isolated in case of a failure.
A ball valve was installed between the two Ts---this allowed for tempering--wide open--little water went through the hose--partially closed--lots of water went through the heater--fully closed would be bad---to much restriction for the pump.
Old 06-18-2013, 05:01 PM   #17
Thanks Mike,
So far I've only added one tee and the other end of the hose is just inserted in the lid to the skim basket. If it proves a success then it will be easy to add a the other for a tidier finish
creeper is offline   Reply With Quote
Old 06-18-2013, 06:37 PM   #18
DIY staff
I see a problem---I should have mentioned--that I carefully laid out the hose so that it was coiled side by side--drilling the backer board and zip tying it--the hose was flat to the backer and coiled like a watch spring--
this gave full exposure to the sun,no hose shaded by any other----it took a while to drill all the holes for the tie straps--
Old 06-18-2013, 06:40 PM   #19
So in others words the box I made is too small...should have used the patio door..with the glass...What about the hose length..enough??
Old 06-18-2013, 10:45 PM   #20
DIY staff
I used 150 feet---the more the merrier--
What you want is a box with a wood frame--plywood back--2x4 frame--just a bit bigger than the door--then an outside 1x6 frame to act as a lip to hold the door.
You are trying to get heat to the hose from direct sun on the top and heat from the black plywood on the back of the hose---kind of like a hose laying on a black top driveway---
Old 06-19-2013, 12:02 AM   #21
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Translation....the more hose you have exposed to the sun, the more heat it will pick up.
I'm thinking a troft about 20' long and 4' wide would work really well. It's all about surface area...the more the merrier....
Old 06-19-2013, 06:34 AM   #22
DIY staff
Creeper you have been after me to learn how to post pictures----I wish I had--a picture is worth a thousand words----
Old 06-19-2013, 06:44 AM   #23
Mike, I would like to see pictures of some of your stuff, but as usual you make your instructions easy to follow.
I have in my minds eye exactly what you mean...its the execution that may be the tricky part
I will post a picture of mine when its completed
The Following User Says Thank You to creeper For This Useful Post:
oh'mike (06-19-2013)
Old 06-19-2013, 02:48 PM   #24
Shadow box made..
Old 06-19-2013, 03:43 PM   #25
JOATMON
ddawg16's Avatar
nice job.......
so....want to sell that "Bridge Island" sign on the wall?
Old 06-19-2013, 06:42 PM   #26
DIY staff
Looking good so far---is the wood frame about the size of the door?
(these people that think you have a garage sale every time you open the door,jeeze)
Old 06-21-2013, 08:31 PM   #27
Better?
frenchelectrican (06-21-2013)
Old 06-21-2013, 08:42 PM   #28
DIY staff
Wow--That is just the thing--a work of art----Have you tried it yet?
Old 06-21-2013, 08:46 PM   #29
JOATMON
ddawg16's Avatar
that's pretty neat....the engineer in me want to instrument it with a few TC's and a flow meter to see what the BTU rating is.
is that real glass or plexi?
Old 06-21-2013, 08:47 PM   #30
Had a really busy day, so only to see if it worked..it does, the plumbing anyway. We will see what the next few days bring
Thanks for your input Mike. Much appreciated
oh'mike (06-21-2013)
Homemade electric pool heater taylorjm Electrical 11 04-22-2013 10:11 PM
Solar pool heater! papageek Electrical 6 05-17-2011 02:04 AM
KStar KS-5 Pool Heater TimN8er Electrical 4 07-02-2009 12:39 PM
Wiring for swimming pool heater and salt system Scooby Electrical 1 06-08-2009 12:59 PM
Pool Care Guide scottiedog Landscaping & Lawn Care 16 06-07-2008 09:41 PM
