Shutting Off Garage Door Sensors (Temporarily) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-11-2008, 02:44 PM   #1
Shutting off Garage door sensors (Temporarily)
One of the sensor wires broke at the bottom of the door (Liftmaster) and now I can't open or close with buttons. Tried all combinations removing wires at Head/power & sensor wires. Door still would not work (with out sensors).
Anyone disable these successfully before?
DeGreg is offline   Reply With Quote
Old 02-11-2008, 04:14 PM   #2
joed's Avatar
Rewards Points: 12,030
I know of no way to disable them or everyone would do it and never install them.
Usually you can close the door by holding the button until it closes. Opening is usually not affected by the sensors.
Old 02-11-2008, 06:29 PM   #3
Custom Cabinet Maker
You should be able to disconnect that door from the motor just by pulling on its rope. Second and I DID NOT say this try putting a jumper between the terminals on the motor the the sensor wires do to, pull sensor wires off first and see if that works
skymaster is offline   Reply With Quote
Old 02-12-2008, 03:26 PM   #4
oh,,and DeGreg.reread the warning below your post before proceeding.
johnrem is offline   Reply With Quote
Old 02-12-2008, 05:12 PM   #5
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
I have seen some different ways to get around the sensors, but as john pointed out, they aren't safe. The sensors were designed for a reason and they need to be properly repaired. In a sue happy world, you do not want a bypassed safety system at your house.
jcalvin is offline   Reply With Quote
Old 02-12-2008, 08:11 PM   #6
newer than a newbie...
Rewards Points: 87
Yes...in a sue happy world, all of the respondents to this thread should start a class-action lawsuit against DeGreg...
mcvane is offline   Reply With Quote
Old 02-12-2008, 08:21 PM   #7
PRO Siding Windows Roofs
even without the sensors the garage door should stop as soon as it hits any resistance. (my sensors have been taped together next to the motor for almost 10 years now)
PKHI is offline   Reply With Quote
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 09:41 AM
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 12:09 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
