Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-04-2011, 01:09 PM   #1
Shower tile fix
I really need some help here other than rip it out and start over - although that may be the most professional and safest thing to do - I do not have that option
I have to replace tiles for a custom shower. We are leaving the floor in tact - its in great shape. However I will tile over it.
I have pulled out the tile and cement board on the walls. Walls are stripped down to the studs. As I pulled out the cement board off the walls, I left about 1/4 to 1/2 inch of cement board wedged between the liner and the cement pan. I can't get it out without potentially poking a whole in the liner. The question is, can I drop my new cement board right on top or should I seal it first with silicone or something?
Once I put up the new CB (I'm using HardieBacker 500) I plan on applying a coat of thin set to the existing floor and CB where they meet. Then I plan on using Redgard to waterproof the seams then thin set and tile..
I attached a pic of the wall
joemeat is offline   Reply With Quote
Old 01-04-2011, 01:28 PM   #2
Tileguy
Bud Cline's Avatar
Shower tile fix
I think you are on the right track but whatever you do DO NOT install nails or screws through the cement board where there is the liner behind it. DO NOT PENETRATE THE LINER for any reason. Let the cement board fly at the bottom. The subsequent thinset/filler will trap the board in place and you will be fine.
What are you going to do with the thickness of new tile at the drain?
Old 01-04-2011, 01:39 PM   #3
Shower tile fix
Thanks Bud... so do you think the silicone first is a good idea? Regarding the drain, I found a product that extents the drain ring by 1/4 in. Specifilly designed for tileing over tile in a dranage area.
Old 01-04-2011, 02:24 PM   #4
Tileguy
Bud Cline's Avatar
Shower tile fix
I see no reason to use silicone for the edge of the wallboard but if your neat there is no reason not to. Just don't smear around too much because nothing will stick to it. Be sure to fill with thinset then liquid waterproof the fill.
That'll work. Be sure to silicone the extension thoroughly to the previous.
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 03:32 PM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 09:19 PM
Building a tile shower ghostrider20 General Discussion 2 03-01-2007 09:54 PM
Shower tile need some help here dirtyb115 Remodeling 2 12-23-2006 01:27 PM
