We had a buch of cracked tiles on the floor of our shower. They have been cracked for awhile(don't ask how long). My husband recently removed all the cracked tiles and there is moisture under the tiles. It makes sense to me, as the tiles were cracked. The question is two fold. One, we have no idea what we are looking at now. It looks like a concrete slab. It is moist, but is already a tad dryer since he removed the tiles. What do we do next. Do we simply lay down the new tiles and assume it was wet bc of the cracks. We are obviously worried about water damage and mold. This shower is on the second floor and there are no obvious signs of a leak or overflow. This shower is used twice a day and the cracks seemed significantly large. My husband is freking out and lost as to what to do next.
Often the pre-slope is missing under the liner---water gets under the mud deck and the sits there--unable to drain the deck---you may have that situation---
I'm guessing you already know you have two choices. You just haven't figured out which to go with.
1) It hasn't leaked so you assume it was done right under the tile. Replace the tile.
2) You question why the original tiles cracked in the first place. They shouldn't have. You suspect that the fact they did is indicating a possible problem with how the shower was installed in the first place. You decide not to take a chance of doing the repair only to later have leakage show up downstairs and you have to tear it up anyhow. But now, X amount of time later, there is X amount of more damage to repair.
There is possibly only one person on the planet that knows for sure how it was done originally. Have you had any other plumbing related issues in the house? I'd use that information too when deciding how to proceed. Usually the worst part of a person's work shows first, but skill and habits don't change much while working in a single home. Just saying.
I disagree^ Tiles do not just crack.When you have several cracked, something moved. Shower pans are sloped for a reason, some moisture is going to get through your grout and to the pan. So some moisture under the tile is not the big problem of course there is a lot more got thru because of the cracked tiles. What I would be worried about is why the tiles cracked. If just for peace of mind I would have someone come in and look at the shower pan and show them where the cracked tile where.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
