Shower Temp. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-05-2015, 12:21 PM   #1
Rewards Points: 4
Shower temp.
I have a leaky cold water handle in my master bathroom bathtub. When we take showers the temp. changes from warm to extremely hot then back to warm. It used to do it, 2-3 times during a shower session. Now it does it a couple times a minute. Is the cold water leak the reason for the temp. fluctuation or is there a bigger problem? Please Help!!!
Rodrigust is offline   Reply With Quote
Old 02-05-2015, 12:36 PM   #2
Rewards Points: 2,488
Shower temp.
In my opinion an external leak would need to vary in intensity to change water temperature at the shower head . What may be happening internally is anyone's guess.
For solutions to these types of problems I've always tried to correct what I know is wrong first and those steps often correct other problems as well. So what I would do is correct the leaky handle problem with new internal parts and then go from there. While down it may be wise to replace parts in both cold and hot.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Rodrigust (02-05-2015)
Old 02-05-2015, 12:53 PM   #3
Rewards Points: 4
Shower temp.
SeniorSitizen, thanks for the tip. I was thinking the same thing. I'll change the handle inurts and go from there.
Old 02-05-2015, 04:20 PM   #4
Rewards Points: 3,360
Shower temp.
Sounds like the mixing valve is going bad. A small leak would not cause this.
Entering your general location can help with answering a lot of times
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 10:20 AM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Peerless oil furnace - keeps turning on when temp exceeds target temp eugenet1979 HVAC 0 12-22-2011 08:30 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
