#1 |
Shower Rod Trouble
Hi. I need to install a new stainless steel shower rod. But My dilemma is that the 6 ft ones are too big and the 5 ft one that I got at HD is too small. I have two 4 inch holes on both sides of the wall where the rod goes in. Now can I fill it in with something so that that 5 ft bar will fit or do I get one custom made. And if filling in the hole is a good idea what would i use? Right now my rod is a bit over 5 ft and is very rusty which is why I need to replace one. Thanks!
#2 |
Shower Rod Trouble
That must be some big shower rod that you had before to leave a 4’’ hole. Measure your old shower rod and cut the 6’ one down to match.
here is a video on installation: http://www.youtube.com/watch?v=edIZF9ha-_0 Last edited by epson; 07-24-2012 at 01:02 AM. |
#3 |
Shower Rod Trouble
But what is your opinion about filling in the hole and making it smaller?
#4 |
STAFF
Shower Rod Trouble
How about decorative pieces of wood at each side and make it look intentional? Or maybe a couple of decorative wall tiles.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Jim |
#5 |
Shower Rod Trouble
Is the 4” hole in drywall or a tiled wall? Can you provide pictures?
#6 |
Average Joe/ex-Navy IC3
Shower Rod Trouble
Most rods are going to be expandable. We just used a curved shower rod, that fit between the walls, and expands to fit. I would suggest the same. Pictures do help though.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#7 |
An old Tradesmen
Shower Rod Trouble
Moved to General forum.
| Display Modes | |
| Shower stall installation | mforeman1 | Flooring | 1 | 04-06-2011 08:39 AM |
| Bathroom Remodel | aworkman | General Discussion | 17 | 03-05-2011 02:21 PM |
| Tile Baseboard on outside of plastic shower pan at linoleum joint? | GaryS | Tiling, ceramics, marble | 2 | 07-26-2009 01:39 PM |
| Honey, I'm going to re-caulk the shower... | homebound | Remodeling | 1 | 02-10-2009 10:11 AM |
| Shower Pan Liner Problem | Hottrod33 | Plumbing | 9 | 02-02-2009 02:02 PM |
