Shower Installation Help Needed - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-24-2005, 04:36 PM   #1
Shower installation help needed
I'm intalling a plastic 36" x 36" shower in a tight space. Plumber says that backer-board isn't necessary to install behind shower walls onto studs. He says that he can simply to install shower onto 2x4 studs of the walls and it will be ok. Is that ok to install a plastic (quite hard plastic probably 1/32 to 1/8 of an inch thickness) shower directly onto studs or should a backer-board be installed in between shower walls and wall studs?? How about vapor barrier? all the walls are inside walls. Thanks for your help.
neonrider is offline   Reply With Quote
Old 08-24-2005, 06:15 PM   #2
The plumber is correct! The stall should be secured to the 2x's. You could install insulation in the walls for sound deadening but it is not required.
plumguy is offline   Reply With Quote
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 01:01 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
Bathroom shower sill installation question bocci Remodeling 2 07-23-2006 01:31 PM
