Shower Grout Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-18-2009, 05:39 PM   #1
Shower grout problem
We've recently noticed that the grout in our shower seems to be turning to a liquid-paste - almost like it's melting. Any ideas as to what's happening?
Reneescorner is offline   Reply With Quote
Old 01-18-2009, 09:31 PM   #2
Rewards Points: 2,906
If you get no responses from the tiling contractors in here, then it's something that normally never happens. In that case, it could be something abnormal with the grout.
Is the grout hard when it's dry and does it only turn soft when you're having a shower?
If so, it could be because someone decided they were going to use white wood glue as an "additive" in the grout to make it stick better. I've heard it's common for bricklayers to add white wood glue to their mortar to help it stick better when repointing brickwork. I've never understood that practice because white wood glue (aka: polyvinyl acetate) re-emulsifies if it gets wet and stays wet for any length of time. A much better choice would be a concrete bonding agent that's also a water based adhesive like white wood glue, but only has a short period of time after it dries that water will re-emulsify it. After that period of time elapses, then it's unaffected by moisture.
There's no telling what a homeowner will do. If they used white wood glue in their grout, it could be the white wood glue simply re-emulsifying due to the wet conditions. And, if it's mostly that glue that's holding the grout together, then the grout will come apart when it's wet.
There is a test for polyvinyl acetate. In the 1961's movie, the "Absent Minded Professor", Fred McMurray plays Ned Brainard, an absent minded college professor who invents a "flying rubber" which he calls "Flubber". "Flubber" was in fact a mixture of polyvinyl acetate (white wood glue) and Borax that was called "gluep" prior to the Disney movie. Since then, it's been called "Flubber" by most people.
I know that you can make flubber out of white wood glue, but I don't know whether using re-emulsified white wood glue would work. If you want to investigate further, try and get a sample of that "melting grout". You can find the recipe for making flubber here: (or just Google "Flubber")
https://www.msu.edu/~pilantpa/rubber...BERFLUBBER.htm
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-18-2009, 10:55 PM   #3
K&B Remodeler/Tile Guy
angus242's Avatar
Is it a relatively new installation? If so, do you know the type of grout that was used?
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-19-2009, 10:53 AM   #4
No it's not a new installation. I've tried sealing the grout which helps for a short period of time and then the same thing happens. When the shower is not in use the grout solidifies. Very odd....
Old 01-19-2009, 11:10 AM   #5
angus242's Avatar
Yes, odd. I unfortunately can't say I've seen this before. There are 2 things that do come to mind.
1) The type of "grout" that was used. If it was some kind of premixed or mastic based material that someone used as grout, that could be the issue. A portland cement based grout shouldn't have this problem.
2) Cleaners. Any type of acid can eat into grout. I don't know if it can fall under the circumstances you mention with the softening/hardening situation you're seeing.
How long was the shower OK before you started seeing this occur? Did any sort of new cleaner start getting applied to the shower about the same time as the grout softened? How old is the shower?
Angus
My Albums
Old 01-19-2009, 12:04 PM   #6
The shower is at least 10 years old if not older. The prior owner did some remodeling and I'm not exactly sure when the shower was done. I noticed the problem with the shower about a year or so after we bought the house. So probably 2006. Cleaners - usually use scrubbing bubbles.
Question about tiny spaces in grout (shower) doogie88 Tiling, ceramics, marble 2 01-05-2009 01:51 PM
Shower floor slope Not Sure Building & Construction 11 06-10-2008 11:12 AM
Caluking instead of grouting tile in shower? KansasWind Flooring 5 03-30-2008 10:43 PM
Sealing grout Crysgrits Flooring 2 02-26-2008 03:13 PM
