Shower Exhaust - Stained Ceiling - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-26-2010, 12:32 PM   #1
Shower exhaust - stained ceiling
I installed a shower exhaust a while ago and vented it to the outside with aluminum duct. I have recently noticed a water stain around the exhaust that is slowly getting worse. I didnt see any stain in the summer but notice it now. I'm wondering if I need to put the exhaust on a timer - I think the cold air in the attic is causing condensation in the duct which works its way back to the joint between the fan and the duct where it leaks onto the ceiling. Does this sound like a reasonable solution - other suggestions?
jmm1678 is offline   Reply With Quote
Old 12-26-2010, 12:45 PM   #2
You are probably either dealing with condensation or leakage from the outside. Does the ductwork vent straight up to the roof, or does it vent out to the side (through a gable or soffit)? If you are venting straight up to the roof, you may have some leakage around the ventcap when it rains.
Using a timer is not a bad idea to make sure that the fan runs long to remove the moisture in the room, but you'll still have condensation issues. You can insulate the pipe in the attic to help minimize the condensation, but make sure that you don't have any roof leakage, also.
clashley is offline   Reply With Quote
Old 12-26-2010, 03:16 PM   #3
Thanks - the exhaust ducting does not go straight up but vents to the side. Is there a specific type of insulation for the flexible ductwork?
Old 12-26-2010, 06:32 PM   #4
Chicago, IL
Michael Thomas's Avatar
Often, when I see flexible bath exhaust ductwork there are dips which can trap condensed water, sometimes when enough water collects the flex duct moves a bit, and there is a sudden flow of water back toward the fan housing.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 12-27-2010, 10:25 AM   #5
Craftsman
JMM, condensation is your problem. Buy an aluminum basting pan (10"x16") and bend it to fit under the duct and adapter (if possible) at your fan (make sure it is under the lowest point of the duct). Cut a couple of small drain holes in the bottom of the duct hose (1/8") where it lays in the pan. This will catch the condensation in cold weather before it leaks out into your ceiling. A timer also helps to keep air moving through the duct longer to dry it.
Superrick is offline   Reply With Quote
Stained Shower Base- Remove Stain Law Building & Construction 1 09-27-2010 05:21 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Clean badly stained grout in shower flyboy_ont Tiling, ceramics, marble 7 05-28-2009 05:48 PM
tiling a bathroom shower ceiling and floor marie conn Tiling, ceramics, marble 2 11-14-2008 01:44 PM
tiling a shower ceiling.... anedoll Remodeling 1 01-01-2007 07:04 AM
