Shower Drain Cover - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-10-2013, 06:42 PM   #1
Rewards Points: 12
shower drain cover
Hello
Just had my bathroom remodeled - went from a tub/shower to walk in shower only.
I bought a different shower drain cover (it matched the tiles) but it's a little too large for the one that is there. My question can I glue this to the shower floor? If so what adhesive/glue should I use..
sunshin49 is offline   Reply With Quote
Old 04-13-2013, 05:09 PM   #2
Must use same size as opening with plumbers putty
unclechubb is offline   Reply With Quote
Old 04-13-2013, 05:16 PM   #3
Rewards Points: 13,228
Where's the picture so we can see what your talking about?
Old 04-14-2013, 02:53 AM   #4
Rewards Points: 258
You should return it and get the correct size.
Being human is the result of heredity.
Being humane is a matter of choice.
retired guy 60 is offline   Reply With Quote
Old 04-14-2013, 06:33 AM   #5
DIY staff
Rewards Points: 7,174
Could you tell us how the shower was built? Is the pan made of packed concrete or some other material?
More info needed--------
Old 04-14-2013, 07:38 AM   #6
Aside from any of the other potential issues with using this wrong sized cover, gluing it down is not a good idea because you would have no access to the drain. There would be no way to snake a clog out of the drain or the like.
HandyAndyRR is offline   Reply With Quote
Old 04-14-2013, 07:59 AM   #7
PoleCat's Avatar
Rewards Points: 1,646
If there is enough solid material around the edge you could use the old cover as a template and shave the new one down to size. Redrill and coutersink new attachment holes and BANG! You got a custom fitted drain cover.
PoleCat is offline   Reply With Quote
Shower Drain in Concrete Slab Install sharp21 Plumbing 4 08-30-2012 11:51 AM
New shower drain installed, but gasket not sealing dryvlyne Plumbing 5 10-23-2011 10:29 PM
Garage Drain Cover matt151617 Plumbing 5 08-09-2011 08:56 PM
Basement Shower Drain bigbran Plumbing 3 02-22-2011 10:21 AM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 01:49 AM
