-   -   shower drain cover (http://www.diychatroom.com/f2/shower-drain-cover-176782/)
sunshin49 04-10-2013 05:42 PM
shower drain cover
Hello
Just had my bathroom remodeled - went from a tub/shower to walk in shower only.
I bought a different shower drain cover (it matched the tiles) but it's a little too large for the one that is there. My question can I glue this to the shower floor? If so what adhesive/glue should I use..
unclechubb 04-13-2013 04:09 PM
Must use same size as opening with plumbers putty
joecaption 04-13-2013 04:16 PM
Where's the picture so we can see what your talking about?
retired guy 60 04-14-2013 01:53 AM
You should return it and get the correct size.
oh'mike 04-14-2013 05:33 AM
Could you tell us how the shower was built? Is the pan made of packed concrete or some other material?
More info needed--------
HandyAndyRR 04-14-2013 06:38 AM
Aside from any of the other potential issues with using this wrong sized cover, gluing it down is not a good idea because you would have no access to the drain. There would be no way to snake a clog out of the drain or the like.
PoleCat 04-14-2013 06:59 AM
If there is enough solid material around the edge you could use the old cover as a template and shave the new one down to size. Redrill and coutersink new attachment holes and BANG! You got a custom fitted drain cover.
