Shower Door Pull Handles Loose - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 11:17 PM   #1
Rewards Points: 16
Shower door pull handles loose
I have a frameless tubular shower door handle back to back, similar to the picture listed. They are loose now and I have tried to tighten them with allen jack but cannot. Is this a two man job and do both handles have to be held together in order to tighten. Can anyone please help?
RICK430 is offline   Reply With Quote
Old 03-07-2009, 04:15 PM   #2
Rewards Points: 5,336
What's the reason you can't tighten the screws? Are they stripped? Wrong wrench?
Try loosening them so you can remove the handles completely. While the handles are off inspect the place where the allen screw comes into contact with and see if there are bite marks on the surface. Then check to see that the allen screws are working properly in the handle by screwing them in and out. If they're stripped, or partially stripped, replace them with new stainless steel ones and reassemble the handles.
Make sure you're using the correct wrench to tighten these or you'll strip them again.
Ron
Old 03-28-2009, 01:38 PM   #3
THAT HANDLE IS A BACK TO BACK SET UP. KNOWING THAT YOU HAVE LOCATED THE ALLEN SCREWS, LOOSEN BOTH OF THE ENOUGH TO BE ABLE TO REMOVE THAT SIDE OF THE HANDLE... NOW TRY TO TIGHTEN UP THE TWO SCREWS THAT FOLLOW THROUHG THE GLASS TO HOLD THE OTHER SIDE OF THE HANDLE. YOU WILL NEED EITHER AN ALLEN KEY OR A SCREWDRIVER, TIGHTEN THEM... DO NOT OVER THIGHTEN, THIS WILL CAUSE THE PLASTIC WASHERS TO BUCKEL OR BREAK. ONCE THIS IS DONE REPLACE THE OTHER SIDE OF THE HANDLE. AS LONG AS THE SET SCREWS OR THE TREADS IN THE HANDLE ARE NOT STRIPPED THIS SHOULD HELP SOLVE YOUR PROBLEM.
HOPE THIS HELPS...
Shower Doors By Design
ShowerDoorDsign is offline   Reply With Quote
Old 03-28-2009, 05:04 PM   #4
Rewards Points: 16
Guys the bottom inside allen jack screw is completely damaged and I tried a screw extractor to extract the allen jack screw to no avail. Do you guy know of any suggestions, I would like to hacksaw the handle off but afraide it way damage the entire glass door or shutter it if I use a electronic saw.
Old 03-29-2009, 11:08 AM   #5
'It didn't work", is okay if you know why it didn't work. It doesn't matter if the inside bottom is damaged, because the screw extractor is the solution.
Why didn't it work?
Did it bite on the inside of the recess?
Would it bite if the hole was deeper?
Did you try the next bigger size extractor?
If you did, why didn't it work?
Too big for the opening?
If it was, go back the the smaller size and drill out the bottom of the allen screw about 1/8" and try again.
This is a trial and error procedure.
Did you buy the extractor set with the drill bits? If not follow, the directions that came with the set you bought to determine the correct drill bit size.
Ron
Old 03-29-2009, 09:39 PM   #6
You need to drill out the allen screw, tighten up the the opposing screws, replace the stripped allen screw and you should be done. Do not use an electric saw to cut the handle, the vibration could make things messy...
Worst case, cut it with a hacksaw and then i can give you the info to contact a company that you can purchase a new handle
shower doors by design
Shower controls loose gamble Plumbing 1 02-13-2009 12:27 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 02:02 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 01:01 PM
