Shower Door Installation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-17-2010, 05:26 PM   #1
shower door installation
how do you install sliding shower doors when a wall is not plumb...other than hanging the door crooked?
cfio is offline   Reply With Quote
Old 10-18-2010, 06:13 AM   #2
There are usually provisions for slight problems built into the design by the manufacturer, but if it is way out, it can be difficult. The solution for that may be shims and lots of caulk.
Old 10-18-2010, 09:45 AM   #3
Rewards Points: 45
I dont understand your question.
The doors usually slide closed into the jamb which is like a pocket that would hide the fact that the wall isnt plumb. If it is really bad the doors should be adjustable.
jegolopolli is offline   Reply With Quote
Old 10-20-2010, 07:52 AM   #4
shower doors have an adjustment on them usually around 30mm, you adjust the frame at whichever side to adhere to the wall measurement.
Bobby_B is offline   Reply With Quote
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 07:07 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
