Shower Door Frame Repair? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-06-2010, 10:43 AM   #1
Shower door frame repair?
The bottom aluminum frame (and the bottom mitered inch or so of the aluminum side frames) have blackened and deteriorated beyond cleaning or polishing. The tempered glass door and hinge are serviceable, so frugal me hates to throw out the whole door and buy new. Is it practical to repair the bottom and perhaps part of the side frames, or do I just bite the bullet and replace the door?
Kennybob is offline   Reply With Quote
Old 02-07-2010, 01:57 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Not an expert, but I spend waaaay to much time on this forum reading about showers and such. No one else has responded so I'll throw in my two cents based on what I've read here.
Repairing the finish is not really an option. Due to the amount of water, constant moisture and cleaning there is not much that will last. Anything you did would be temporary at best.
You might consider replacing the damaged areas, but you would need to either contact the manufacturer for replacement parts or get very, very lucky at a habitat for humanity store or such. This would more than likely involve removing the whole unit. You mention a "tempered glass door and hinge" so I am thinking you have some sort of pivot door, so seals and making sure there are no leaks is also a concern. (I had to do repairs on our subfloor floor last year due to a pivot door that leaked.)
Biting the bullet and replacing the door is probably your best bet.
Fiberglass shower repair ponch37300 Kitchen & Bath Remodeling 5 03-10-2009 03:43 PM
shower repair phunam04 Plumbing 2 02-04-2009 11:45 PM
Shower Faucet Repair MsPettus Plumbing 4 05-19-2008 10:39 PM
How Do I Repair an Improperly Installed Shower Floor MartinGale Flooring 3 11-26-2007 08:36 PM
Shower Door Repair startingreferralbiz Plumbing 2 01-11-2006 07:00 AM
