Shower Door Frame Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-14-2013, 09:24 AM   #1
Shower door frame question
Hope this post is in the right place, as I'm new here. Having some issues with the channel for my glass shower doors. The weep holes on the inside rail of the channel drain some of the water out of the shower door frame. But, there is nothing to allow the water to drain from the outside rail, into the inner channel and eventually into the tub. The mold is nasty as I basically have standing water in the entire rail of the shower door frame. Any suggestions? Could I just drill a small hole along the inner door frame to allow the water out of the channel? Thanks.
toolmom is offline   Reply With Quote
Old 10-14-2013, 01:51 PM   #2
Rewards Points: 274
You can drill the hole but it would be better if some professionals can drill that.
alexjoe is offline   Reply With Quote
Old 10-14-2013, 02:44 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Sure you can.
This is a simple task that does not require a pro to do.
sublime2 is offline   Reply With Quote
Shower remodel question farmery Remodeling 5 03-23-2013 11:27 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 08:11 PM
Prep Shower Walls / Shower Bench Question LeviDIY Remodeling 8 06-10-2011 05:09 AM
Custom Shower Plumbing Question PhilStubbs Plumbing 0 04-24-2011 09:39 PM
AAV Shower Question PADIY Plumbing 8 01-20-2009 04:49 PM
