Shower Caulking Help Please - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-12-2011, 08:54 PM   #16
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I'm no expert, but those four yellowish tiles suggest there have already been repairs. Then the floor tiles don't really match the wall tiles (at least that is not what I would have chose). Is it possible someone added another layer of tiles to the floor trying to cover other problems? If so, I'd say that shower is way past its expiration date.
Old 11-12-2011, 11:06 PM   #17
Rewards Points: 4,796
99% chance there is damage under the tile and mortar.
jeffnc is offline   Reply With Quote
Old 11-12-2011, 11:26 PM   #18
A Little Of Everything
Rewards Points: 1,364
Okay, so this is the shower at an apartment you rent? Speaking as a landlord, I can assure you that "fixing" this shower is not your job. Also, the truth is that in order to fix it correctly, it is going to have to be completely torn out and replaced. Not only is that going to be expensive, it's almost certainly beyond your expertise.
If your landlord will not fix that shower - which apparently he feels no need to do - I'd strongly suggest you make the best of a bad situation. That includes cleaning it, and keeping it clean. Nothing more.
Get ahold of some Microban disinfectant/antibacterial/antifungal compound. It will do the job that bleach will NOT do. Mix it and use it as per directions. About 4 years ago I used this stuff in a house with a really bad mold problem. To this day there is no mold problem! It's going to set you back a few bucks (about $30 per gallon) but you'll get the results you need.
DrHicks is offline   Reply With Quote
The Following 2 Users Say Thank You to DrHicks For This Useful Post:
Bud Cline (11-14-2011), scyarch (11-13-2011)
Old 11-13-2011, 04:02 AM   #19
paper hanger and painter
chrisn's Avatar
Rewards Points: 386
That shower has been past due for a loooooooooong time
chrisn is online now   Reply With Quote
The Following 2 Users Say Thank You to chrisn For This Useful Post:
Blondesense (11-13-2011), Bud Cline (11-14-2011)
Caulking large gaps in shower enclose+to caulk or grout a tub with tile. pilsengirl Plumbing 1 07-31-2011 12:36 PM
caulking shower stall questions, removal, grout sealing etc detyianni Plumbing 0 11-29-2010 09:00 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
caulking shower question amandalc04 General DIY Discussions 9 01-31-2010 12:05 AM
Shower caulking donjt81 Kitchen & Bath Remodeling 5 11-20-2009 01:41 PM
