Should This Be Tested For Asbestos - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-30-2014, 04:10 PM   #1
Should this be tested for asbestos
Two products are attached to the floor of this bathroom. One is a sheet above the joists and below the flooring (some has been spray painted white, some remains tan). The other is in a similar location, but colored black (most of it looks like it has been ripped out).
I know the only way to know if something contains asbestos is to get it tested, but is this the sort of thing you would spend the time and money to have tested or am I just being paranoid? Parts of the house are 1908 and others are 1940.
Should this be tested for asbestos-img_20140330_125026-1280x960-.jpg   Should this be tested for asbestos-img_20140330_125037-1280x960-.jpg   Should this be tested for asbestos-img_20140330_125054-1280x960-.jpg   Should this be tested for asbestos-img_20140330_125120-1280x960-.jpg
zipmsp is offline   Reply With Quote
Old 03-30-2014, 04:53 PM   #2
Rewards Points: 6,652
If you are not sure, you need to send a sample off to be tested. Most likely just Masonite board. Think of it as Wood pulp Fiber board, before it becomes Cardboard or paper.
The Following User Says Thank You to gregzoll For This Useful Post:
zipmsp (03-30-2014)
Old 03-30-2014, 06:25 PM   #3
joed's Avatar
Rewards Points: 12,892
Probably tentest type board put up to keep the dirt from falling through the cracks in the plank flooring laid directly on the joists.
The Following User Says Thank You to joed For This Useful Post:
zipmsp (03-30-2014)
Old 03-30-2014, 08:52 PM   #4
Thanks. I plan on having both tested.
Old 03-30-2014, 09:00 PM   #5
Most times it does not have Asbestos. If Tentest, no Asbestos to worry about. Celotex is another product that looks like this. I would be worried about having the fibers from it floating in the air, causing you to get itchy.
If you plan on taking it down, treat it like you do with Fiberglass Insulation. Mask, eye protection. long sleeved shirts and pants. Wet the product down with Water with a little bit of Dish Detergent in it. You can use a Garden Pump sprayer to wet it down, while you remove and bag it.
Then just toss in the trash dumpster.
zipmsp (03-30-2014)
Old 03-30-2014, 09:10 PM   #6
Rewards Points: 256
Also place a fan in the window and seal open part of window where fan is not.
JustinK is offline   Reply With Quote
The Following User Says Thank You to JustinK For This Useful Post:
zipmsp (03-30-2014)
Old 03-30-2014, 09:58 PM   #7
Especially if you are gutting a room. I found that the fan looks worse then you do, when pulling down old Gyprock.
When we gutted our bath, one of the neighbors came knocking on our door, due to it looked like Smoke going out of the window that the fan was in. Nope, just a bunch of Gypsum & Cement/Plaster.
It is odd how it takes less time to gut a space, then it does to put the drywall up and finish it.
OOPS! Stack disconnected when I tested my work... WillK Plumbing 1 02-20-2012 06:04 AM
Heat pump not working! Tested capacitor! MikeVila HVAC 28 01-11-2012 04:01 PM
Do i need 3 samples tested for asbestos? MLMIB Building & Construction 7 03-23-2011 10:39 AM
Where to get well water tested? theedudenator Plumbing 19 01-23-2010 07:16 PM
