Should I Tape This Exhaust Duct To The Attic Vent? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 12:10 AM   #1
Should I tape this exhaust duct to the attic vent?
This duct is from my bathroom's Vent Fan, it's blowing air into my attic when I turn my bathroom's fan on.
Should I just use some duct tape and tape it to that particular hole in my attic's roof? Not sure if that hole is where the exhaust duct is suppose to go.
Thanks in advance!
entropyjx is offline   Reply With Quote
Old 11-22-2011, 07:01 AM   #2
Rewards Points: 2,238
They have vents designed for exhaust ducts.
You really shouldn't use a "roof" vent ("Pod").
Or, vent it through your soffit vents.
Most standard, duct tape is not suitable.
Wait for additional responses.
Don't vent it directly into the attic!
rossfingal
rossfingal is offline   Reply With Quote
Old 11-22-2011, 08:03 AM   #3
Rewards Points: 5,336
Install a separate vent to the exterior for the bath exhaust. And as Ross said, nix the duct tape. Use a metal tape instead.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
rossfingal (11-22-2011)
Old 11-22-2011, 08:23 AM   #4
joed's Avatar
Rewards Points: 11,988
I can't tell from the inside but that could be just detached. If that is an attic vent then no you should not connect to it. If that is the proper roof cap for a fan vent then you need to repair the connection.
The Following User Says Thank You to joed For This Useful Post:
New Roof marknok Roofing/Siding 4 08-06-2011 12:41 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 06:17 PM
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 09:47 PM
Soffit Vent Sizing - Really Hot Attic dmo069 Roofing/Siding 7 12-04-2008 10:33 PM
Can I use duct tape? Dusty HVAC 2 09-27-2006 09:28 PM
