Should This Be ?glued? ? Caulked? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 05:39 PM   #1
should this be ?glued? ? caulked?
These lights were installed a little over a year ago, and it looks like they put some kind of glue that has not stayed (you can see the clear glue there) and the "hole" at the top a little exposed. Do you think this should be fixed? I can pull up the light and cover the hole. Should I remove the glue and apply caulk? I recently bought some silicone caulk for something else and I wonder if I should apply this?
Thanks!
junkemail0707 is offline   Reply With Quote
Old 03-22-2011, 05:53 PM   #2
DIY staff
Rewards Points: 7,174
That looks like mildew covered caulk----Like you suggested---remove old caulk--center light over hole--
Secure with silicone.---Fine plan---Mike---
Old 03-23-2011, 07:26 AM   #3
I don't like to use silicone anywhere on painted surfaces. It is hard to remove and can't be painted over. Use a siliconized latex such as DAP. Realign the fixture and tighten hardware, it should stay put. A bead of caulk on top/sides helps keep out moisture.
Old 03-23-2011, 08:04 AM   #4
Rewards Points: 5,336
Seal it on 3 sides. Leave the bottom open.
Ron
Caulked Molding Joints WirelessG Painting 6 12-29-2010 07:41 AM
new constr, windows not caulked? agnathra Building & Construction 5 12-03-2010 02:43 PM
Should tongue and groove siding be caulked? apara Building & Construction 5 08-15-2010 07:07 PM
