Shopless in CA
Before you go any further, you better check local building codes. Unless you live out in the boonies, I'm willing to bet that the car port is not permitted...especially since it has inclosed sides. There has been a crack down on that in my area...the most common reason is because people are turning their garage into an apartment and renting it out to people who in most cases do not have a legal reason to be in the country.
After the garage is taken up...they build a car port to have some type of garage....and will sometimes even convert it to an extra room.
If you get caught....hefty fine and you have to tear it all down.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
