Shelf Clips? Can't Find Anywhere! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-17-2013, 02:54 PM   #1
Shelf clips? Can't find anywhere!
I have a built-in bookcase in my house and am looking for clips that are the same, or similar, to these:
I've been to a number of hardware stores, Home Depot, etc., and they usually take one look and laugh at me. Has anyone seen these or know where I might get more clips? Am I better off replacing the whole system with something more modern?
Any help is much, much appreciated! Thank you.
siliconwafer is offline   Reply With Quote
Old 02-17-2013, 04:46 PM   #2
Rewards Points: 13,300
The ones I've seen only have one tab top and bottom not two.
Where did you look in HD? They have the clips back in the storage are, like where the wire shelving is.
May just have to change out the tracks. White tracks and clips would look better anyway.
Old 02-17-2013, 05:01 PM   #3
Nest Home Improvement
NestHI's Avatar
Can you find a name or any markings on the tracks. If you have a name or number you can search on Google and can probably find a vendor carries them.
Home improvement simplified! Serving the Triangle (Raleigh, Durham, Chapel Hill). Please visit us at www.NestHomeImprovement.com
NestHI is offline   Reply With Quote
Old 02-17-2013, 06:10 PM   #4
MarginallyQualified
Rewards Points: 2,464
Check with a commercial refrigeration contractor (or supplier).
Old 02-18-2013, 01:07 AM   #5
Are these called clamps? You will find them in hardware stores. Show them one sample.
leenamark1 is offline   Reply With Quote
Old 02-18-2013, 01:24 AM   #6
Rewards Points: 6,652
Nope, they are called a "Shelf support". A hardware store employee is just going to look at you as if you grew a third eye, while standing in front of them. The ones that the hardware stores would have, would be for the shelf brackets that they stock.
As for the OP, that is a hard style to find, so you may end up having to replace the bracket with one that allows you to use a different style of shelf support. You could ask also over in http://www.woodworkingtalk.com/ since most of those guys/gals do cabinet building, and other types of fine wood work, and may have a site that they know of, vs. trying to search through amazon or ebay for those supports.
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 12:29 PM
Niche, Glass shelf to back wall? wraiththe Tiling, ceramics, marble 0 12-15-2011 03:46 AM
Find the Right Contractor for Two Home Improvement Projects mdawson3k General DIY Discussions 10 05-16-2011 03:34 PM
Where to get fabric/tarp clips like these? Mod Dig Building & Construction 4 09-23-2010 11:27 AM
Hurricane clips... is this ok? TravisT Building & Construction 5 12-24-2007 05:41 PM
