Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-12-2005, 01:13 PM   #1
feb
sheetrock
I am taking wallpaper off my walls and some of the sheetrock paper is coming down also. When I put sheetrock mud over the tear, it bubbles up. I than have to cut the bubble and redo it. How can I stop this? Also, what can I use to spray on the wallpaper to make it easy to come off?
feb
feb is offline   Reply With Quote
Old 08-12-2005, 01:35 PM   #2
sheetrock
To cut down on bubbles put little dish soap in the mix.
I think I heard that dish soap or liquid dish detergent mixed in water. I am sure you make a strong mix. After scoring the paper spray the wall and let it soak in. Should come off
JustaFramer is offline   Reply With Quote
Old 08-26-2005, 10:32 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
sheetrock
The joint compound bubbles up?
Or are you leaving the floppy "paper" part of the tear?
You need to cut out any loose "sheet" from the "rock" before skimming a tear with mud
slickshift is offline   Reply With Quote
Old 08-26-2005, 10:35 AM   #4
slickshift's Avatar
sheetrock
I use a hand steamer if needed
It's like a big funky iron
I rarely use any chemicals
Old 08-28-2005, 01:45 PM   #5
aka:awesomedell
Send a message via MSN to housedocs
sheetrock
Get a product called DIF, mix with water and spray on the wallpaper, it will release the glue & make it fairly easy to remove.
To avoid the bubbles in the drywall mud when skimming over torn face paper, pre prime the area with a product called GARDZ, made by Zinnser. Both of these products are available thru lumber yds or discount stores like Wally world.
HTH
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 08-28-2005, 10:31 PM   #6
Contractor
sheetrock
I use a garden sprayer and warm water. DIF never seemed to mak a DIF except for $$'s. I just keep it wet until it peels like a ripe banana, takes patience. Mop up the glue with a big sponge and rinse often. Let dry.
My hangers prefer a shellac based primer. I don't ask questions, just do it.
Teetorbilt is offline   Reply With Quote
Old 09-02-2005, 11:13 PM   #7
slickshift's Avatar
sheetrock
Do you mean your paper hangers prefer a shellac-based primer on a wall before they hang paper?
Old 10-02-2005, 09:08 PM   #8
2pyrs
sheetrock
feb
I don’t understand how you are getting bubbles in your mud? are you using premix or are you mixing your own? Are you putting tape on wall, seams or trying to patch holes? There is a paper they make you can put on your wall to cover old wall paper and then you can paint over it as long as the wall is in good shape.
2pyrs
2pyrs is offline   Reply With Quote
Sheetrock question Vengence Remodeling 4 07-13-2007 11:42 AM
Sheetrock nightmare MRZ Painting 12 05-25-2007 10:23 PM
pipe leak & sheetrock damage santogr General Discussion 2 03-04-2007 02:44 PM
Reparing sheetrock abelsu Painting 8 02-23-2007 10:41 AM
