Sheet Rock Repair/Lower Bay Window Area - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-28-2009, 11:07 AM   #1
Sheet rock repair/Lower Bay Window area
Hi- I have have a kitchen/breakfast area baywindow that has suffered some water damage. The sheetrock, and moulding have been removed from the area 2" below all three windows. I now have to replace the sheetrock which I know I can do. What has me stumped is the inner radius where the sheetrock corners meet. Is there a form for this or is this a "trick" of the trade? Should I just hire someone to do this?
Thanks.
VEEDUB is offline   Reply With Quote
Old 09-28-2009, 05:18 PM   #2
Rewards Points: 5,336
If this is either a 30 or 45 degree bay, you just cut flat panels so the pieces touch one another. Then you tape and compound the seams.
What radius are you speaking about?
Ron
Old 10-03-2009, 09:44 AM   #3
Drywall contractor
Rewards Points: 1,070
Using the metal reinforced paper "corner bead" as opposed to regular tape will help keep your seams straight. The angle is likely 22.5*, but as Ron said, you just cut the drywall edge square and butt to the other piece. If there IS actually a radius, it's because the finisher couldn't finish the angle properly and chose to "round" it out. A flexible rubber knife is often used for this.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Shower in Window jchri66 Remodeling 1 05-27-2008 01:50 PM
Window doesn't slip well Not Sure Building & Construction 3 08-12-2006 09:12 AM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
