-   -   Sheet rock repair/Lower Bay Window area (http://www.diychatroom.com/f2/sheet-rock-repair-lower-bay-window-area-53967/)
VEEDUB 09-28-2009 10:07 AM
Hi- I have have a kitchen/breakfast area baywindow that has suffered some water damage. The sheetrock, and moulding have been removed from the area 2" below all three windows. I now have to replace the sheetrock which I know I can do. What has me stumped is the inner radius where the sheetrock corners meet. Is there a form for this or is this a "trick" of the trade? Should I just hire someone to do this?
Thanks.
Ron6519 09-28-2009 04:18 PM
If this is either a 30 or 45 degree bay, you just cut flat panels so the pieces touch one another. Then you tape and compound the seams.
What radius are you speaking about?
Ron
bjbatlanta 10-03-2009 08:44 AM
Using the metal reinforced paper "corner bead" as opposed to regular tape will help keep your seams straight. The angle is likely 22.5*, but as Ron said, you just cut the drywall edge square and butt to the other piece. If there IS actually a radius, it's because the finisher couldn't finish the angle properly and chose to "round" it out. A flexible rubber knife is often used for this.....
