Originally Posted by UpComingBuilder
What kind of sheet rock do i use:
For bedroom walls, .
1/2" for residential applications of framing 16" OC.
Ceilings, .
1/2" for Residential applications of framing 16" OC.
Some prefer to use 5/8" because of it's increased rigidity. I don't see the need for it, when framing is 16" OC.
basement walls and ceilings, .
Other options (over standard sheetrock) due to the high moisture content/humidity of basements:
Moisture Resistant (Framing may be required to be closer than 16" OC)
XP Board - Mold and mildew resistant.
Paperless Denshield - Fine Fiberglass mesh facing, requires skim coating surfaces to complete installation.
pretty much all around a house..
I know they change the code almost every year, I'm pretty sure we use 5/8" blueboard. For the fire safety. But just wanted to know what kind you use and the thickness of it. Sorry if its a bad question but I'm going to school in a few months just want to get a jump start before I go. Almost all my posts is just so I could know a little more about remodeling.
Single family homes are 1/2". There is no change for this. Exception: any connected walls/ceilings to an attached garage.
Multi unit (apartments/condos/hotels/2 family separation walls/garage areas connected to main home, etc) = 5/8" Fire rated. Common areas of apts and hotels may require double 5/8".
Each layer of 5/8" gives a 1/2 hour fire-rating. 2 layers = 1 hour.
BTW: Blue board is for Plaster. Standard sheetrock is for drywall. Standard sheetrock is not fire-rated, unless it is labeled/classified as such. "F/R" will be printed on the sheets..
Sheetrock in general: Building Plans will list it as "GWB" - Gypsum Wall Board.
