Sheet Metal Hurricane Box Repair - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-30-2014, 10:51 PM   #1
Rewards Points: 1,606
sheet metal hurricane box repair
I have a sheet metal hurricane box that's custom made for a window.
This is the window.
This is the hurricane box.
It was originally welded sheet metal, but a bunch of lumber fell over it and two of the seams failed, as indicated.
I thought about rewelding it, but the more I look at it, the more I am thinking a better way to make the joints is to use strips of angles instead.
Do you think using something like JBWELD with angles PLUS a few drilled holes for nuts/bolts makes a better joint?
miamicuse is offline   Reply With Quote
Old 05-30-2014, 11:32 PM   #2
Rewards Points: 1,270
Reinforcing it with 1" angle is a great idea.
ED
de-nagorg is offline   Reply With Quote
Old 05-31-2014, 01:05 AM   #3
Rewards Points: 6,652
Take it to a local metal shop and have them reweld the seams with a MIG welder. Along with reinforcing the unit.
Old 05-31-2014, 03:25 AM   #4
(the original)
Rewards Points: 756
Just reweld it. Think about this...what does it protect? Simple answer: the glass. Structural integrity is in the framing, and no cover or shutter adds to that.
ratherbefishin' is offline   Reply With Quote
Old 05-31-2014, 03:01 PM   #5
The problem is that the weld job on it was bad to begin with. It is a wonder that it was able to stay together this long. The bead should be one continuous joint. If the welding was done properly.
The Following User Says Thank You to gregzoll For This Useful Post:
de-nagorg (05-31-2014)
what is the angled sheet metal in front of my wall registers? aboynamedmoose HVAC 3 01-29-2012 10:39 PM
metal paint on sheet rock joeyc Painting 2 04-18-2011 05:04 PM
Loose sheet metal screws harrysanders Building & Construction 4 05-30-2010 09:16 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 03:11 AM
