Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-28-2011, 11:41 AM   #1
Question
Shed plan
Hello, first time user on this site. Hope I am posting this in the correct area.
My plan is to build a shed in my backyard... I have been trying to find plans online but everything says free plans until you select the one you want and they want $$$.
Last year I poured a 10x10 concrete pad, So the plan is to make it a 10x10 shed. I have never done this before so looking for help. I have actually done a lot of home improvements, I believe I can do this. looking for a step by step guide just to read over before starting. never done any framing with wood before.
Not sure what else to say.
Thanks in advance
dru15 is offline   Reply With Quote
Old 07-28-2011, 12:29 PM   #2
Not so new
12penny's Avatar
Shed plan
Lots of threads on the subject if you do a search. Or...the box stores have DIY books on the subject.
I'd read first then come back with specific questions.
Also, contact your building dept and find out if permits are required. We like permits here.
And welcome.
12penny is offline   Reply With Quote
Old 07-28-2011, 01:29 PM   #3
Experienced
Jackofall1's Avatar
Shed plan
The cost of the plans would be well worth the agrivation they will save, I would go ahead and buy the plans, this should give you a material list that make things much easier to get right materails with minimal waste.
Mark
Old 07-28-2011, 01:59 PM   #4
Shed plan
Yes, I purchased a book from the local book store on sheds. But did not have plans and step by step. I will do some more research and then come back with my question, I thought this might be to general.
Old 07-28-2011, 03:58 PM   #5
the Musigician
DangerMouse's Avatar
Shed plan
Before I built my first shed, I walked into the garage and studied how it was made.
Pretty much the same thing. Your local library has books you can borrow to study too.
Thank You Mr. Franklin!
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 07-30-2011, 04:01 PM   #6
Shed plan
Go to ypur library. There are probably a dozen books their on building sheds, garages,etc.
beerdog is offline   Reply With Quote
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General Discussion 32 10-23-2012 09:54 PM
Sinking Shed willise Building & Construction 3 05-04-2011 12:34 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Shed Power Plan zpm Electrical 5 05-19-2009 04:33 PM
Subpanel to Shed - Check my plan NateHanson Electrical 9 04-26-2007 10:56 PM
