Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-17-2011, 03:25 AM   #1
Sheathing
When I install the plywood sheathing do I put it right on the foundation or is it flush with the sill plate?
Hrose77 is offline   Reply With Quote
Old 07-18-2011, 01:54 AM   #2
Sheathing
Try not to contact concrete w/ wood, if untreated. Whatever you do, make sure you air seal either inside, outside, or both; that means caulking, EPDM gaskets, and/or taping (use non-hardening materials).
Old 07-18-2011, 07:07 AM   #3
Sheathing
The sill plate and rim joist should be in the same plane as the foundation edge. The plywood should extend down past the sill plate ( by an inch or so) to cover the sill plate concrete connection.
Ron
B. Franklin 1759
Old 07-18-2011, 10:49 AM   #4
Sheathing
I'm I'm extending down past the sill plate then do use a pressure treated strip so avoid rot?
Old 07-18-2011, 11:21 AM   #5
the Musigician
DangerMouse's Avatar
Sheathing
If the plywood is in contact with the concrete or ground, be sure it's not "just" pressure treated, but pressure treated FOR ground contact!
There IS a difference and inspectors can fail you if the proper material is not used and you will have to do it all again.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 07-18-2011, 12:41 PM   #6
Sheathing
Ron: What is the need to extend the plywood if you have an EPDM gasket under the sill plate?
Old 07-18-2011, 04:52 PM   #7
Sheathing
It keeps wind driven rain from getting through. The poured foundations are sometimes a little wavier then the sill seal thickness. This allows air infiltration as well as water.
It also looks neater.
Ron
B. Franklin 1759
Old 07-21-2011, 04:35 PM   #8
Moderator
Sheathing
Add a metal flashing under the sheathing as any contact with the concrete (moisture reservoir) wall could wick to the wood. Bad enough the p.t. mudsill contacts the sheathing without a capillary break; http://www.greenbuildingadvisor.com/...-building-code
Remember, #5; http://publicecodes.citation.com/ico...9_3_sec017.htm
Gary
Clothes taking longer to dry?
Mold on roof sheathing!!! DIYMILF Roofing 10 08-14-2011 10:11 PM
Replacing Rotting Sheathing Behind Chimney. fredhead Building & Construction 4 11-19-2010 09:57 AM
New roof and Sheathing - Install new fascia before or after? hartkem Roofing 2 06-01-2009 01:12 PM
Moisture on Inside of Sheathing elburritoloco Building & Construction 18 01-19-2009 09:16 PM
Please, help with sheathing and stud placement Mrmusic Building & Construction 2 09-10-2008 05:52 PM
