-   -   Sheathing (http://www.diychatroom.com/f2/sheathing-110979/)
Hrose77 07-17-2011 02:25 AM
Sheathing
When I install the plywood sheathing do I put it right on the foundation or is it flush with the sill plate?
jklingel 07-18-2011 12:54 AM
Try not to contact concrete w/ wood, if untreated. Whatever you do, make sure you air seal either inside, outside, or both; that means caulking, EPDM gaskets, and/or taping (use non-hardening materials).
Ron6519 07-18-2011 06:07 AM
The sill plate and rim joist should be in the same plane as the foundation edge. The plywood should extend down past the sill plate ( by an inch or so) to cover the sill plate concrete connection.
Hrose77 07-18-2011 09:49 AM
I'm I'm extending down past the sill plate then do use a pressure treated strip so avoid rot?
DangerMouse 07-18-2011 10:21 AM
If the plywood is in contact with the concrete or ground, be sure it's not "just" pressure treated, but pressure treated FOR ground contact!
There IS a difference and inspectors can fail you if the proper material is not used and you will have to do it all again.
DM
jklingel 07-18-2011 11:41 AM
Ron: What is the need to extend the plywood if you have an EPDM gasket under the sill plate?
Ron6519 07-18-2011 03:52 PM
It keeps wind driven rain from getting through. The poured foundations are sometimes a little wavier then the sill seal thickness. This allows air infiltration as well as water.
It also looks neater.
Gary in WA 07-21-2011 03:35 PM
Add a metal flashing under the sheathing as any contact with the concrete (moisture reservoir) wall could wick to the wood. Bad enough the p.t. mudsill contacts the sheathing without a capillary break; http://www.greenbuildingadvisor.com/...-building-code
Remember, #5; http://publicecodes.citation.com/ico...9_3_sec017.htm
Gary
